What is a User Defined Function Block and what are the advantages of using it?
Nov-8th, 2017 8:15
User Defined Function Block or UDFB is a function, either written in the Ladder or C Editor, that is designed to perform a specific task, such as control an oven. Any function can be used as a UDFB, with the single exception of the Main function.
In addition to its code, a UDFB may include any of the following:
  • Input and output tags to transfer values into and out of the function.
  • Local tags, which only exist within that function.
  • Global tags, structs, and arrays.
To use a UDFB just Drag & Drop it into the desired function, then link tags to the Function IN and Function Out parameters. Note that you can display the parameter description by mousing over it.
UDFB & Library1b
You can access a video tutorial via this link:
http://www.youtube.com/watch?v=rb5WyCztLWw&list=PLFBq_OH6_be7snAZAycZzQMvAWjHkX9Pz
