Does UniStream support SQL?
Nov-6th, 2017 14:41
Yes, SQL is supported by UniStream PLCs only.
This is possible with version 1.18.60 onwards.
It is important to note that:
·         Version 1.18.60 supports SQL communication with Microsoft SQL only.
·         Version 1.19.83 supports SQL communication with Microsoft SQL and My SQL
Attached an example and installation document.
You may find more information on UniLogic help file under home/SQL
2 out of 2 found this helpful
